Activity › Forums › Adobe Premiere Pro › Flicker removal, ringing of fine lines on subject’s jacket
  • Flicker removal, ringing of fine lines on subject’s jacket
    Posted by Mbelli on May 11, 2006 at 4:30 am
    I have an interview where the subject wore a fine fabric jacket. It rings, particularly around the neck.
    I was previously running Edius and was able to remove the flicker with their anti-flicker filter. This particular filter’s effect could be reduced, so I went down to 70 or so for optimum results (this way the entire image wasn’t softened too much)
    I switched this project to Premiere Pro 2 and all is great, except I can’t get rid of this ringing without really softening the image. I’m using the field options/”flicker removal”. This really softens everything.
    Is there not a way to reduce the effect of “flicker removal” in the fields options? I guess PP2 doesn’t have a seperate antiflicker filter. Or might there be another way to fix this like problem like using a blur?
    Any help appreciated.
    Mike Velte replied 20 years, 4 months ago 3 Members · 2 Replies
  • Joep88
    May 11, 2006 at 9:16 am
    Maybe you can export the interview with the option “no fields” in
    the export options.
  • Mike Velte
    May 11, 2006 at 11:12 am
    If the flickering area does not more a lot, I would use a track matte to blur just the area affected.
