Activity Forums Apple Final Cut Pro Legacy Flicker problems with digitized super 16mm film
  • Flicker problems with digitized super 16mm film
    Posted by Emily Needell on November 30, 2011 at 11:25 pm
    Hello,
    So I have a bunch of digitized super 16mm film that I am editing in FCP. However, in some of the shots, there is a weird flicker (this is AFTER using Cinema Tools to reverse Telecine, or de-interlace, the footage). I tried using FCP’s flicker filter, but to no avail.
    Any suggestions? Is there another flicker filter I can use?
    Emma
    Brad Wright replied 14 years, 5 months ago 2 Members · 1 Reply
  • Brad Wright
    December 1, 2011 at 1:51 pm
    Are you seeing this problem on a external monitor that is interlaced? If you step frame by frame are you seeing this flicker? Try removing the Telecine in Compressor. Drag your file into compressor and select a ProRes codec encoding option. Click on the frame control tab. Turn on frame control. Under de-interlace click the popup button and set it to Reverse Telecine. Give that a shot.
    Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
