Activity Forums Apple Final Cut Pro Legacy flicker problem with FCP and AJA Io
  • flicker problem with FCP and AJA Io
    Posted by Scott on June 30, 2005 at 11:37 am
    I am experiencing a problem when scaling down a shot and keyframing it from one side of the screen to the other. It flickers or jitters.
    Have tried de interlacing, trashing preferences, and reinstalling FCP.
    Also happens with wipes.
    Running G5 with FCP HD 4.5
    Any ideas?
    Scott replied 21 years, 2 months ago 2 Members · 2 Replies
  • Chris Poisson
    June 30, 2005 at 5:40 pm
    Scott,
    Try doing this with DH Box from Digital Heaven, only 10 bucks.
    Or, make sure the clip stays on even scan lines, and put the flicker filter on it set to max. If that doesn’t work, add a little (.5) gaussian blur.
  • Scott
    July 10, 2005 at 8:57 am
    Found the problem. Field order of sequence was set to lower rather than upper.
    Thanks for your help.
    Scott
