Activity Forums Broadcasting Flicker problem. Help please!
  • Flicker problem. Help please!
    Posted by Michel Doumit on August 4, 2009 at 9:02 am
    Hi all,
    I’m having flickering issues with what seems to be all shots where the camera looks down on my scene and travels laterally. More specifically, my scene shows a board game and the cam is looking down at it directly from the top (parallel to the board) and traveling across it. As soon as i break the angle, the flickering stops. I’m using 3ds max 2009 and i’m rendering with vray. I actually faced the same problem in after effects once. I had a traveling camera from left to right and multiple 3d layers parallel to its path. I wasn’t able to resolve it. I’m almost sure this is the same problem. Movement parallel to the camera plane flickers. I tried, rendering to fields and applying directional blur in post. Any suggestions are more than welcome.
    Thank you.
    Dean Harrington replied 16 years, 8 months ago 2 Members · 1 Reply
  • Dean Harrington
    December 21, 2009 at 4:06 am
    Apply the ‘Stop motion Blur’ plug-in (FCP has this and I believe all other editing NLS do to.) Try the following settings:
    Time lapse – 1
    Steps – 1
    Initial opacity (52) flexible quality
    Decay opacity – 0
    Blend operator – add
