Activity › Forums › Apple Final Cut Pro Legacy › flicker on old footage
Posted by Dan Crouch on March 26, 2013 at 9:45 amI have a flickering on some old footage that I can’t get rid of.
It was Pathe footage, cut in fcp. I have slowed it down to 75 percent.Anoyingly the dvd authoring has started so I can only re export the video layer as sound has been done.
Please can anyone help with this.
Shane Ross replied 13 years, 6 months ago 7 Members · 7 Replies -
Rafael Amador
March 26, 2013 at 11:11 amWhat I see is some frame blending that looks very ugly.
I guess introduced on the slow down and may be by a wrong managing of data bases.
Try keeping the speed at 75%, but uncheck “Frame Blending” on the speed window.
Which is the time-base of the archive footage, and which is the sequence time base?
rafael -
Neil Patience
March 26, 2013 at 11:14 amIn some ways the age of the footage and its very interesting content forgives a certain amount of flickering and artefacts. Having said that It looks like a field issue or maybe some frame blending thats not helping. Does de-interlacing help at all?
best wishes
Neil
http://www.patience.tv8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7 -
Chris Tompkins
March 26, 2013 at 12:04 pmIt looks like the shutter flicker from the old film footage. By slowing it down you are magnifying it.
Chris
Dan Crouch
March 26, 2013 at 2:11 pmThanks v much all for the post’s.
I am busy until tonight so will check out the suggestions.Re the authoring, the sound is mixed and ready, but the video layer can be re done so need to get this sorted before we commence.
It was slom-mo’d at 75 percent and de-interlaced.
I did pull the original clip into Avid but the same thing happened. I can only think it was filmed at a really strange speed and the conversion is confusing it. I have a feeling it may need to be re tele-cinied (which would be a pain).
Thanks again for post’s
Dan. -
Joe Barta iv
March 26, 2013 at 2:36 pmMost of these early film cameras ran at 18fps, so you’d have to start there with the telecine and adjust accordingly as you move it into digital editing, yes, a pain.
Jerry Wise
March 26, 2013 at 3:17 pmit sort of looks like “lower field” footage that was dropped into an “upper field” timeline.
Shane Ross
March 26, 2013 at 4:49 pmAs said, old footage was shot at 18fps. And the flicker is due to early cameras not having rock steady shutters, so exposure varied.
The flicker is normal…it’s on pretty much all footage from that era. Let it go. We are used to seeing that by now…it’s not distracting. Well, unless you are in your 20’s and might have an issue with old footage…many young people don’t want to even watch black and white.
I say live with it. Trying to fix it will be a frame by frame job that’ll last quite some time.
Shane
Little Frog Post
