Activity Forums Apple Final Cut Pro Legacy Flicker Occur when using Video Transition
  • Flicker Occur when using Video Transition
    Posted by Diana Yuen on May 26, 2005 at 9:29 am
    I am using SpinBack 3D Transition for my DV Footage, When play back in Broadcast video monitor, Flickering occur when i use “Full quality” in Playback setting.But If i use “Medium” for the playback setting, no flickering will occur. I have try to apply “Flicker Filter” already, but it seems no use at all.. How can i fix it? thanks!
    Diana Yuen replied 21 years, 3 months ago 2 Members · 2 Replies
  • Everett Bowes
    May 26, 2005 at 10:46 am
    just a guess, but have you tried to use the de-interlace filter on both the out-going and in-coming clips?
  • Diana Yuen
    May 26, 2005 at 11:17 am
    Yes, I have tried to use it for both clips. but still can’t works
