Activity › Forums › Apple Final Cut Pro Legacy › flicker moire
  • Chuck Reti
    April 3, 2008 at 3:41 pm
    What kind of problems are you having at production level that are causing you difficulty? What format are you shooting in,
    DV25, DV50, SD, HD, HDV?
    Unless you can monitor your shoot through exactly the same path as your material will be distributed, it’s very difficult to anticipate a result.
    Without more info, all I’ve got is:
    -Talent shouldn’t wear herringbone-patterned jackets.
    -Don’t use set pieces with finely detailed diagonal lines.
  • George Sloan
    April 6, 2008 at 6:33 am
    I don’t know what is causing the moire in production
    only that it often shows up on my time line after capturing I am
    refering to SD using a JVC GY HD 100u camera.
