Activity Forums Adobe After Effects Flicker in imported AVI files
  • Flicker in imported AVI files
    Posted by Knut Högvall on June 8, 2009 at 11:15 am
    I have taken motion screen dumps in SnagIt in AVI format. The original dumps look great. But when I import the AVI files into AE, using the original’s resolution and frame rate, I suddenly get the most horrific flickering, lags, jumping cursors, you name it. A perfect AVI file looks positively horrible after being imported into AE.
    What am I doing wrong?
    Knut Högvall
    Documentation Manager
    Polystar OSIX
    Adrienne Norris replied 16 years, 8 months ago 4 Members · 4 Replies
  • Simon Bonner
    June 8, 2009 at 1:36 pm
    I’ve had similar problems after using a different screen capture programme. Not sure what the issue was, but it seemed to render out fine.
    Simon Bonner
    youtube.com/simonsaysfx
  • Kevin Camp
    June 8, 2009 at 3:26 pm
    i know a lot of people use camtasia to make many of the video tutorials you see here. i’m sure they have a free trial if you wanted to check that out…
    as far as the footage issue, the avi container is usually not a problem… do you know what codec snagit is encoding the screen captures as, and can you set it to use a different codec?
    usually the first step in troubleshooting footage problems is knowing as much about the footage as you can. knowing the codec can go a long way to fixing footage issues. if it is recording using a codec like mpeg-2, mpeg-4 or h.264, then it is probably using interframe compression. this type of compression will create problems for ae. you should be able to convert it using an nle or another media utility to codec that uses only intraframe compression or no compression.
    other potential issues with footage could be how ae interprets the footage. select the footage in the project window, choose file>interpret footage>main. since it is a screen capture, make sure that ae is not separating fields. also make sure that the frame rate is correct.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Knut Högvall
    June 9, 2009 at 6:23 pm
    Thanks. I am currently checking Camtasia out.
    Knut Högvall
    Polystar OSIX
  • Adrienne Norris
    December 31, 2009 at 11:22 pm
    I’m having the same problem with SnagIt and AE. I checked the footage interpretation and everything seems alright. The video I captured was set to uncompressed, so I can’t figure out how to keep the crisp cleanness of the original video in After Effects so that I can add my effects to it.
