Activity Forums Apple Final Cut Pro Legacy flicker in final cut with magic bullet
  • Jason W. miltt
    May 15, 2005 at 4:19 am
    i forgoto to say that this happens mainly in the lower bottom part of the image.
  • Jason W. miltt
    May 15, 2005 at 4:20 am
    i just found out that this could be because of slow motion too. i tried FC slow motion and it is there, i tried with Boris optical flow and is there too. without slow motion results seem fine.
    how to do it then?
  • Chris Poisson
    May 15, 2005 at 4:39 pm
    ezichko,
    If I were trying to do a film look, first of all I would use Gfilm from nattress.com over MB anyday. If you’re doing speed changes, it may help to render the sequences out to self-contained QT movies before you put on your film look filter.
    Also, it would be helpful to know what kind of footage you’re dealing with, how it was shot, frame rates etc.
