Activity Forums VEGAS Pro Flicker from still image problem
  • Flicker from still image problem
    Posted by Griff Hamlin on May 29, 2009 at 1:14 am
    I’m trying to import a .PNG file that is some music notation. I’m using Vegas Pro 8.
    I get the image imported okay and it would be fine except for the flickering. I have checked the “reduce interlace flicker” option but it does not seem to help.
    I’ve searched google for the last 2 days straight trying to solve this problem… it’s as if I’m the only person who has ever had it.
    Are there ANY tricks or suggestions you might have?
    Mike Kujbida replied 17 years, 3 months ago 3 Members · 2 Replies
  • Theo Van laar
    May 29, 2009 at 8:36 am
    You can reduce the resolution of your PNG files to the resolution of your project before importing into Vegas
    Theo
  • Mike Kujbida
    May 29, 2009 at 10:03 am
    As I recall, music notation is a lot of very fine lines which are always a problem for video.
    If at all possible, bring it into a paint program and try to make the lines thicker.
    If that’s not possible, add the Gaussian Blur FX.
    Set Horizontal to 0, and Vertical to 0.001 to 0.003.
