Activity Forums Apple Final Cut Pro Legacy Flicker filter
  • Posted by Dan Martland on September 28, 2005 at 5:29 pm
    hi,
    Does anyone have the same problem as me. I have tried appying the flicker filter in final cut on my current project and turned it to max. But for some reason, it doesnt seem to make any difference to the footage. (as far as i can see anyway)
    I thought that this filter would give it a film look but im not too impressed. Maybe im doing something wrong.
    Hope you can help!!
    Dan
    Graeme Nattress replied 20 years, 11 months ago 4 Members · 5 Replies
  • Chris Poisson
    September 28, 2005 at 9:02 pm
    The flicker filter is not intended to give you a film look. For that, the best thing out there is Gfilm at nattress.com.
  • Dan Martland
    September 28, 2005 at 9:18 pm
    Oh right, thanks for that.
    Just out of interest, what is the flicker filter for then?
  • Thaxter Clavemarlton
    September 28, 2005 at 10:01 pm
    [dantv1] “what is the flicker filter for then?”
    All together now…
    “It filters out flicker.” 😉
    If you make a freeze-frame from moving video and it “flickers” because of too much motion between the two video fields (a FRAME is made up of two FIELDS that actually contain slightly different images),
    the Flicker Filter will eliminate this animated motion.
    Its adjustable because the more you reduce the “flicker” the “softer” the image can become.
    It WILL degrade the quality of the video if applied to your whole video track, as the resolution is reduced.
    Some people are of the opinion that simply degrading video quality creates a film look.
  • Dan Martland
    September 28, 2005 at 10:06 pm
    Thanks for that, helped alot
  • Graeme Nattress
    September 28, 2005 at 11:17 pm
    Nattress Film Effects gives you everything you need to make your video look filmic – try out the free demo at http://www.nattress.com
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
