Activity Forums Apple Final Cut Pro Legacy flicker effect
  • Posted by Marsh Birchard on December 15, 2010 at 7:25 pm
    I am trying to layer a flicker effect over still images intending to create a strobing pattern that increases in frequency over time. The goal is that the strobe effect increases in frequency very subtly over the course of 30 to 60 minutes. Modify->Speed would be ideal as I could enter a percentage value, but I can’t modify speed of a track that only contains slug. Any ideas how I might achieve this effect would be greatly appreciated.
    M
    Andrew Rendell replied 15 years, 5 months ago 4 Members · 3 Replies
  • Rafael Amador
    December 15, 2010 at 7:46 pm
    [Marsh Birchard] “but I can’t modify speed of a track that only contains slug”
    What about nesting the track first?
    rafael
    http://www.nagavideo.com
  • Michael Gissing
    December 15, 2010 at 9:43 pm
    You can also make a quicktime movie of the stills sequence and speed change that.
  • Andrew Rendell
    December 21, 2010 at 6:06 pm
    I’m not sure what you’re trying to do, but “strobing pattern” does raise certain alarm bells. This may not be a problem at all for what you’re after, but it’s worth being aware of the issues surrounding photo-sensitive epilepsy and making sure your insurance is up to date.
    https://www.hardingfpa.com/resources/photosensitive-epilepsy-pse/
