Activity › Forums › Boris FX › Flicker and Shake on BCC-avx or RED?
  • Flicker and Shake on BCC-avx or RED?
    Posted by Mike Meyerson on November 27, 2009 at 8:50 pm
    I noticed the free flicker and shake effect for BCC-fxplug…what’s the easiest way to get an effect like that with either BCC-avx or Boris Red?
    thanks
    Mike Meyerson replied 16 years, 10 months ago 2 Members · 2 Replies
  • Peter Mcauley
    November 30, 2009 at 5:56 pm
    Currently this filter is FxPlug exclusive and cannot be used in any host other than FCP or Motion. It might migrate into other products in our line but for now the requirements to use the fiter are that you install it into Final Cut Studio host.
    If you just need some flickering and shaking of the video clip, then you might want to check out the BCC Film Damage filter (you can disable all of the features in this filter except for Flicker and Shake) or the BCC Jitter filter. These filters are accessible in other hosts, such as RED of BCC AVX.
    Cheers,
    Peter.
  • Mike Meyerson
    December 1, 2009 at 3:49 am
    thanks peter…will give that a try.
