Activity Forums Zaxwerks Flicker
  • Serge Hamad
    October 29, 2007 at 3:22 am
    Hi Henry,
    I had the same issue a couple of times when using several Invigorator instances. Are you doing so?
    I could eliminate the problem by trashing the prefs.
    Are you using presets maps?
    let us know if this works for you. BTW. Make sure you are using the latest version of ProAnimator.
    Salut.
    Serge
  • Enrique Borja
    October 30, 2007 at 4:22 pm
    hi serge, thanks for your answer, well, yes, im usin several instances of proanimator, i have several solids with PA aplied to them, if thats what you mean.
    how can i trash the prefs??
    and yes, im usin presets.
    thanks in advance
  • Serge Hamad
    October 30, 2007 at 8:16 pm
    Hi Henry,
    Your prefs are located in the main ProAnimator folder.
    Just make sure before trashing them to have your license handy as you will have to use once you restart.
    Before trashing anything you could also try to use your preset image as a layer map and see if this works. You can find your images in the environments or Zaxwerks maps folder depending on what kind of preset you are using. This trick worked for me once. I think that Invigorator had trouble loading my TGA file.
    Last but not least I would generally advise you to pre-render some of the ProAnimator layers with an alpha and subtitute the movies with your ProAnimator layers.
    I hope this helps.
    Salut.
    Serge
    “InvigoMany” is back in stock! https://www.nyc-visual.com
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Enrique Borja
    October 30, 2007 at 8:54 pm
    thanks serge! i think that rendering each instance will be the fast solution, ill try the other when i finish this proyect, thanks for the advice !
