Activity Forums Blackmagic Design flick decklink studio 2
  • flick decklink studio 2
    Posted by Hung Han on September 21, 2010 at 4:49 pm
    Hi
    I’m using a Decklink Studio 2 and The DeckLink 7.9 drivers.
    I’m running the application “Blackmagic LiveKey” and when i start the application the output flick once and then run normally. I’m receiving a sdi signal as input and “21 composite out” as output.
    Someone has any suggestion to fix it or it could not be fixed?
    Regards,
    Hung
    Adam Pakula replied 14 years, 5 months ago 3 Members · 2 Replies
  • Kristian Lam
    September 28, 2010 at 7:39 am
    Hi Hung,
    When you start LiveKey, it sets the card up into capture mode so everything you’ve described sounds normal.
    regards
    Kristian Lam
    Blackmagic Design
  • Adam Pakula
    March 30, 2012 at 12:01 pm
    Hello Kristian.
    I need your help urgently!!.
    I bought UltraStudio Pro from B&H and cant get it to work.
    I followed instructions to the T. I have certified Asus P6x58 E-premium motherboard. NEC chipset bios is 3025 and driver is 2.1.28 i believe which is higher than what is recommended in the manual. Still no luck. Please help. Im loosing valueble prodcution time and am personally on the hook for recommending Ultrastudio pro.
    Please email me at adam pakula @ live .ca
    thank you
