Activity Forums RE:Vision Effects Flex registration problem?
  • Flex registration problem?
    Posted by Arjen Abbestee on October 23, 2010 at 12:32 pm
    Just received my new computer (12core MacPro). So I installed everything fresh.
    But now when I render a comp with Flex in one of the layers I get some frames with the demo-mode cross through them. When I render again the cross is on other frames. On my old machine I never had this problem.
    The project is new, by which I mean it is created on my new machine. Everything is installed fresh.
    Anybody else experiencing this?
    Arjen Abbestee replied 15 years, 3 months ago 4 Members · 6 Replies
  • Peter Litwinowicz
    October 23, 2010 at 5:38 pm
    Why don’t you send your registration name and key to us at techsupport (at) revisionfx (dot) com and we’ll take a look at what’s going on (do not post here!)
    Pete
    RE:Vision Effects.com
  • Arjen Abbestee
    October 23, 2010 at 5:39 pm
    Will do.
    Arjen
  • Florian Baumann
    November 30, 2010 at 1:05 pm
    hi arjen,
    could you solve the problem? i have the same issue here…
    florian
  • Arjen Abbestee
    November 30, 2010 at 3:08 pm
    I re-installed everything (from system to plugins and everything in between) and so far so good. Except for a couple of plugins from digital Film Tools that now refuse to register…
  • Dario Antonioli
    June 2, 2011 at 3:38 pm
    have you got the solution? I have the same problem.
  • Arjen Abbestee
    June 2, 2011 at 3:53 pm
    See my previous post. After re-installing from scratch everything started to behave. A pain in the …., because I have to enter several serial numbers for every plugin. My original number, the update number to the next version and so on until I reach the current version. You’d think after 20 years of computing a better solution can be found. It’s tempting to use a pirated serial to avoid all this hassle…
    Good luck,
    Arjen
