Activity › Forums › Apple Final Cut Pro Legacy › FLex Files in Final Cut Pro
  • FLex Files in Final Cut Pro
    Posted by Jennifer Marshall on April 21, 2009 at 1:06 am
    I was wondering if there was a way to include flex files from a telecine file into Final Cut Pro. I was looking online and saw an article mention Cinema Tools. Is there a way to just use the flex files directly into Final Cut Pro?
    Daryl K davis replied 17 years, 5 months ago 3 Members · 3 Replies
  • Andreas Kiel
    April 21, 2009 at 2:08 am
    What do you mean by “directly”? You just can choose “File->Import->Cinema Tools Telecine Log…” create a new data base and got the FLx data in your FCP project.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Jennifer Marshall
    April 21, 2009 at 2:24 am
    Oh, that’s awesome. Thank you.
  • Daryl K davis
    April 21, 2009 at 2:32 am
    Use FLEX files all the time. But you need to use Cinema Tools to create a database to provide the functionality you need down the road.
    Here’s how:
    From in FCP go to File/Import/Cinema Tools Telecine Log
    From the Import a Cinema Tools Telecine Log window go down to the New Database button and create a new Database. Be certain to set the correct default settings for your Film Standard and TC settings. Save The Cinema Tools database with a name that correlates to the FLX file you are importing (ie: CT_01 for your flex file 01.FLX which should correlate to lab tape 01)
    Then you can choose a log file (your FLEX file) and open. You will see how all your log is imported via XML and the clips pop up in your bin ready for batch capture. After you batch capture you can set theKey Number column and see how it matches your burn-in on your media.
    That’s the basics. I usually create a separate Bin for each Tape, as well as a seperate folder on the scratch disk for each tape. There are many other steps involved before you want to jump into doing a major project like a feature film (eg. reverse telecine, link media in Cinema Tools, etc.) . Check out the manual, it’s all there.
    Good luck.
    DK Davis / Editor/ Post Super
