Activity Forums Apple Final Cut Pro Legacy Flex file problem
  • Flex file problem
    Posted by Martial Bachoffner on June 26, 2005 at 11:51 am
    Hello,
    We received a flex file from a service bureau.
    We open the flex file in Cinema Tools, import the batch capture list in FCP, everything seems to be ok.
    The start and end time logged in FCP are the same than in the flex file in Cinema Tools.
    After the capture in FCP, the start time and the end time of the clip captured are different, between 2 and 10 frame were added.
    Why?
    Regards,
    Martial
    Martial Bachoffner replied 21 years, 2 months ago 2 Members · 2 Replies
  • Steven Gonzales
    June 26, 2005 at 2:57 pm
    Perhaps you captured with handles?
    Perhaps when you imported the batch list into final cut, your sequence setting was not a 29.97 timebase. If you import a batch list with a sequence setting of 24 or 23.98, all frame number in the timecode of the batch list above 23 will be converted. A timecode of 1:01:30:29 becomes 01:01:31:05. This will cause the capture to be incorrect.
    Another possibility is you need to calibrate your decks timecode offset as described in the Final Cut manual.
    I hope this might help.
  • Martial Bachoffner
    June 26, 2005 at 5:10 pm
    Thanks Steven,
    I will check for the deck.
    Regards,
    Martial
