Activity Forums Adobe Photoshop flatten to new layer – leave layers intact
  • flatten to new layer – leave layers intact
    Posted by Peter Ralph on September 25, 2006 at 8:50 pm
    Is there a way in PS CS2 to flatten all the layers in an image to a new layer but leave the original layers intact beneath the new one?
    Richard Harrington replied 19 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jimmy Brunger
    September 26, 2006 at 9:44 am
    Just stick all the layers you want to flatten into a new layer set and then duplicate that – flatten it – and keep the other one as an editable backup.
    If it’s a big file I’m working on I usually also save two identical PSDs, calling one ‘BACKUP’ for when I’m flattening files into mattes and faces.
    …It’s very easy to accidentally save over a layered file when you’re making mattes quickly and then close it and lose the history! A couple of jobs I’ve had to do again cos of that!
  • Peter Ralph
    September 26, 2006 at 12:56 pm
    thanks Jimmy – I can do it with 3 or 4 commands but I thought there was a keyboard shortcut. It seems I am not the only one who would have a use for such a thing
  • Jimmy Brunger
    September 27, 2006 at 9:17 am
    When you say 3 or 4 ‘commands’..what do you mean? I’m always trying to find quicker ways to do stuff!
    off topic – have you noticed how the action & title safe guides in PS are not right? I rarely use them as I have my own file template set up for UK 16:9 broadcast…but I was doing a non-broadcast job yesterday and was using the title safe preset on a DV PAL widescreen new document (with guides) and noticed the vertical title safe is WELL within the actual legal safe. Bit boring I know, but if it’s something you need, it’s good to know!
    *AE 5.5 Pro – *PS CS1 – *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / BMD DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation
  • Richard Harrington
    September 27, 2006 at 11:24 am
    Make new Layer…
    Hold Down Option Key or Alt ey
    Choose Mege Visible
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Peter Ralph
    September 27, 2006 at 2:01 pm
    is that trick documented anywhere?
  • Jimmy Brunger
    September 27, 2006 at 9:56 pm
    Good one! I usually just flatten, but that will come in very handy… ta.
  • Michael Hancock
    September 28, 2006 at 12:44 am
    I haven’t tried this on CS1 or CS2, but it works in Photoshop 7 (yeah, yeah, I know, I need to upgrade). Make a new layer, then Ctrl+Alt+Shift+E. That’s on a PC. I assume it’s Ctrl+Option+Shift+E or something similar on a Mac.
    Mike.
  • Justin Spina
    September 30, 2006 at 6:35 am
    In CS2 you don’t even need to make a new layer first. Just hit CMD(CTRL)+OPT+SHFT+E and that will merge visible all on a new layer above all your other layers.
    October 2, 2006 at 1:31 am
    In my books and DVDs it is…. lots like it in the book Broadcast Graphics on the Spot
    You’ll also find tips in the blog PhotoshoforVideo.com and the companion podcast
