Activity Forums Adobe Premiere Pro “Flat” settings for HD Camcorder?
  • “Flat” settings for HD Camcorder?
    Posted by Joe Derone on August 18, 2010 at 9:11 am
    I may be completely off on this but I will admit that the whole area of Digital filming is relatively new to me, I have some knowledge that I gathered here and there but far from coherent and well based.
    I am seeking some advice as to the best way to capture footage “flat” so that I can achieve a better result when editing / colour correcting later.
    I am filming with a Panasonic HDC-HS700, it is the top line of their consumer range, not a “Pro” device (prosumer maybe). It is a Full-HD camcorder that can also record at progressive 50fps (I have the PAL version).
    My intended workflow is to edit the recorded footage in Premiere Pro / After Effects and to also apply colour correction etc. there.
    As I understand, it is preferrable to record footage “flat”, i.e. without many of the automatic adjustment the camera makes “on-the-fly” if you record in the normal consumer operating modes. Is this the gist of it?
    If yes, what would be “typical” settings for a camcorder (the Panasonic has quite a lot of manual options) to record footage that is best suited for post in PPro or AE (especially for Colour Correction?)
    As far as I understand, standard camcorders aim at producing images which can be instantly shown on external devices or burned to DVD directly without the need for post-processing, hence the automatic on-the-fly adjustments.
    And I am under the impression that if you indend to post-process the footage anyway, it would be better to switch off these automatic adjustments.
    Now, it seems fairly common sense but again I am not sure if there are some that are good, even for post-processing and others that aren’t.
    I am basically looking do draw on some advice from people who do this professionally. I would be happy for any input to improve my filming and post.
    Joe
    Joe Derone replied 16 years ago 2 Members · 2 Replies
  • Vince Becquiot
    August 18, 2010 at 7:56 pm
    The rule of thumb, which would involve a waveform monitor, is to keep the blacks a bit higher than you’d want and avoid any overexposure to give you freedom in post.
    Of course, that’s easier said than done. First you’d need a camera with a high video dynamic range, those are the higher end model, you also need control over the master pedestal, and finally a good broadcast monitor (camera LCD is close to useless) or a waveform monitor. Or you could make use of Adobe OnLocation.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Joe Derone
    August 19, 2010 at 2:33 pm
    Thank you, that certainly pointed me in the right direction, and I am not ashamed to admit I had to look up what the master pedestal is.
    I am guessing that any consumer camcorder including mine does not go HDR for video, so I will just have to experiment.
    Joe
