Activity › Forums › Creative Community Conversations › Flat Screen CRT Monitors
Posted by Erik Hermesman on May 15, 2005 at 5:15 amIm looking to purchase two 17 or 19 inch crt flat screen monitors.
They need to support (and look good) at a resolution of 1280×1024 pixels.
My budget is (both monitors combined) $300.
Can you recommend anything?
Thanks alot.
Steven L. gotz replied 21 years, 4 months ago 2 Members · 2 Replies -
Steven L. gotz
May 15, 2005 at 7:57 pmYou can pick up a couple of Dell 19″ at 1600X1200 for around $99 each:
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Steven L. gotz
May 15, 2005 at 8:03 pmI forgot to mention that refurbished items can often be the best deal around. Why? It isn’t really used. It came from a customer who didn’t know how to use it, or it had a bad cable end, or something was wrong. The thing is, a refurbished model is tested 10 times more than a brand new one. If it comes in with a complaint, even if it is “No trouble found” (quite common) they test the heck out of it. Whereas a brand new one gets a little testing and is sent out. Why? Because that is good enough in that vast majority of cases. But your refurbished unit will be tested in all details.
I used to work for a place that refurbished units, a a test engineer. So I know the deal. I often buy refurbished. Especially monitors and printers.
Steven
