Activity Forums Maxon Cinema 4D Flat render from C4D?
  • Flat render from C4D?
    Posted by David Gruwier on September 2, 2014 at 7:45 am
    Is there any way to decrease the contrast of Cinema 4D renders, so that you get more dynamic range and a more flat and desaturated image straight in the picture viewer? I do a lot of CGI integration on footage shot on very flat cameras, and I have to flatten my render out of Cinema 4D. It’d be so much better if I could just get it flat in the first place, so I could retain the information in shadows and highlights.
    Adam Trachtenberg replied 12 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 2, 2014 at 10:10 pm
    If you render to linear gamma, 32 bits, you will get as much dynamic range as you can possibly need. Also, if you render to the picture viewer without specifying a save location, you can go in after the fact and do your color/tone grading in the Picture Viewer. You do that by going to the filter tab at the right and checking the “Enable Filter” box. Then you can adjust saturation, brightness, contrast, exposure gamma, and even RGB curves.
    Once the image is to your liking you can File>Save As. Just make sure you choose Animation or it will only save single frames.
