Activity Forums Maxon Cinema 4D Flat look with shadows
  • Flat look with shadows
    Posted by Javier Saldivar on November 19, 2013 at 7:50 pm
    I want to achieve a 3D look with no shading, making objects look like flat vector illustrations but in 3D. I tried by creating a material and using the luminance channel instead of the color channel. Then I tried adding a compositing tag to the object and enabling the “matte” option. Both approaches work great in achieving that “flat look” but I can’t get the objects to receive shadows with either of these techniques.
    To better illustrate the issue I rendered a frame (below) and I’m also attaching the C4D project file (studio R14)
    From left to right:
    – The first cube has a regular material applied (with color channel enabled) and it casts and receives shadows.
    – The second cube has a material where we only have the luminance channel enabled.
    – The third cube has a compositing tag applied with the matte option enabled.
    – The tall column is there just to cast shadows.
    As you can see the second and third cubes have the flat look I am looking for but for some reason cannot receive shadows.
    Any idea how to achieve that flat look while the objects also receive shadows?
    6813_flatlookshadows.c4d.zip
    Cassius Marques replied 12 years, 10 months ago 2 Members · 1 Reply
  • Cassius Marques
    November 19, 2013 at 8:17 pm
    Ordinary material, uncheck the matte object, and check compositing background.
