Activity Forums Adobe After Effects FLAT LINES
  • FLAT LINES
    Posted by Dan Lachevre on November 12, 2007 at 1:00 pm
    I’ve done the simple-flat line-animation thing over the years with so many different tools:
    3d Stroke, Particular, Echo filter, Invig and just had a read up on Layer tools from Zaxwerks.
    It still seems there is still no simple way to create flat, rendered, shadow casting lines / ribbons in AE that move and bend around objects. I know the basic principle of AE’s 2d / 3d space is the reason but I thought I’d see what the thoughts out there are.
    Is it simply “go into a 3d program” ? What are the preferred methods.
    [The echo filter method is probably the closest but never gives great results and takes too long to render.]
    Steve Roberts replied 18 years, 10 months ago 2 Members · 1 Reply
  • Steve Roberts
    November 12, 2007 at 1:39 pm
    Did you search the COW for “ribbon”?
