Activity Forums Adobe After Effects Flashlight/Torch/Flickering Light
  • Flashlight/Torch/Flickering Light
    Posted by Dan Turner on April 7, 2010 at 2:13 pm
    Ok, apologies if this has already been covered (I did a lot of searching but couldn’t find the right answer), I also wanted to do it in FCP, and I’ve worked out ways to do it fairly basically, but AE might be a much better option.
    I’d basically light to use a simple effect where there is 2 layers of the same clip, the background one flickering in time with the music (probably using opacity) and the top layer is a roaming vignetted spotlight effect, like someone shining a flashlight over it (the same clip as the layer underneath)…
    Can anyone suggest the best way to do these? Preferably a way to automate the flickering… does AE have sound reactive settings? Also I know Lux does a similar effect to the flashlight right?
    Thanks a lot.
    Todd Kopriva replied 16 years, 5 months ago 2 Members · 1 Reply
  • Todd Kopriva
    April 7, 2010 at 10:33 pm
    There’s information on this page about using audio to drive animations.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
