Activity › Forums › VEGAS Pro › flashing when fading clip or out..why?
  • flashing when fading clip or out..why?
    Posted by Vic Shadez on December 10, 2018 at 10:43 pm
    this is a random issue but its important I fix asap. whenever I fade a clip in or out. it will flash where its cut. it usually only happens when the clip is above another video track.
    John Rofrano replied 7 years, 9 months ago 2 Members · 2 Replies
  • Vic Shadez
    December 10, 2018 at 10:58 pm
    I noticed when I bypass all effects it goes away. why would that happen?
  • John Rofrano
    December 18, 2018 at 1:04 pm
    [Vic Shadez] “I noticed when I bypass all effects it goes away. why would that happen?”
    Usually this is a graphics card issue. The FX are probably GPU accelerated so turning them off eliminates the GPU and thus the problem. Make sure you have the latest drivers. Sometimes the latest drivers are the problem and you need older drivers. It’s a tough one to debug. Find someone who is using the same graphics card and see what version drivers they are using (assuming they don’t have the problem).
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
