Activity Forums Apple Final Cut Pro Legacy Flashing when exporting
  • Flashing when exporting
    Posted by Andrew Guddat on June 25, 2010 at 10:55 pm
    I am importing editing exportting in .mov with H.264, Linear PCM, Timecode codec and when i play the exported video in quicktime and vlc it skips. on quicktime or VLC it handles the skipping a little different and it happens at different times. during playback in FCP it has NO skipping. and it tends to only skip a few seconds before or after a new shot. I AM NOT leaving spaces in-between the clips.
    any help or suggestions would be appreciated, I’m kinda a rookie in FCP
    John Fishback
    replied 16 years, 2 months ago
    2 Members · 1 Reply
  • John Fishback
    June 28, 2010 at 9:34 pm
    If you are editing H.264 clips in FCP, that’s probably the cause of your problems. FCP doesn’t like H.264 for editing. You should only use codecs you find in the Easy Setups. Use Compressor or MPEG Streamclip to convert the H.264 to ProRes and edit with that.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
