‘Flashing’ frames after CS4 Render
Hey all,
I wonder if anyone has come across this before….
Every time I render a certain clip out of CS4 I get some strange flashing towards the end of the file. I’m 100% sure it’s not in the timeline or the source footage and it isn’t even consistent in the renders, it’s always towards the end but not always the same frames?
It’s Pro Res going in and Pro Res coming out although I’ve tried various different codecs with no luck. The timeline contains a boujou camera, nulls and a few adjustment layers. Even with all the layers turned off (apart from the source file) I still get the same problem.
I’ve attached a clip to better highlight the problem –
https://reels.creativecow.net/film/1830-flicker-problem
Any help will be truly appreciated as always!
Cheers,
Dave
