Activity › Forums › Apple Final Cut Pro Legacy › Flash to Final Cut
  • Flash to Final Cut
    Posted by Steve Turcotte on April 3, 2009 at 3:54 pm
    I’m having a nightmare trying to figure out the right sequence settings for editing a Flash document in Final Cut.
    My Flash document aspect ratio = 1280 x 720
    *What would be the best export setting to use?
    Also what would be the ideal AV settings & sequence settings be in Final Cut?
    I’ve tried various combinations, but my animation sequences are usually a bit skewed and need rendering.
    Are there any settings that would allow me to edit together Flash Quicktime sequences without rendering?
    Steve
    Steve Turcotte replied 17 years, 6 months ago 2 Members · 2 Replies
  • John Fishback
    April 3, 2009 at 5:24 pm
    Perian (a QT plugin) allows you to play flvs in QT. You can also export them as QT files – perhaps ProRes or DVCPro HD given your dimensions. If your Flash is an H,264 you can use QT or Compressor to make your files. Neither flvs nor H.264s are meant to be editing formats. The quality will depend on the data rate of your flvs or H264s. The higher the data rate the better the quality.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Steve Turcotte
    April 3, 2009 at 9:22 pm
    Steve
