Activity Forums Compression Techniques Flash settings?
  • Flash settings?
    Posted by Chris Heuer on March 20, 2010 at 12:59 am
    Hello. I am exporting a one minute video for a website. I exported an Animation file that I dropped into Adobe Flash Encoder. I used the OnV 6 (I think that’s right) encoding and set the data rate to 1200.
    The web designer said the file isn’t working. She got this error:
    “This type of FLV video (not Flash MX format) can only be imported without re-encoding. Do you want to import this video as it is without re-encoding”
    Any info on what Flash encoding is best (most compatible) for the web?
    Chris Heuer
    Freefall FX, LLC
    Mark Luigjes replied 16 years, 5 months ago 3 Members · 2 Replies
  • Daniel Low
    March 20, 2010 at 2:26 pm
    Isn’t that ‘error’ message basically saying that you don’t have to re-encode the video. In other words it should work fine as it is?
    [Chris Heuer] “Do you want to import this video as it is without re-encoding” “
    I’d say ‘Yes’ to that.
    Sent from my iPad Nano.
  • Mark Luigjes
    April 12, 2010 at 12:34 pm
    Agreed, re-encoding a already encoded video will only result in loss of quality. Flash MX recognizes the video is in a acceptable format and shows this in a alert box. Nothing to be worried about.
