Activity › Forums › Adobe After Effects › Flash intros import.
  • Flash intros import.
    Posted by Frank Manno on November 9, 2005 at 1:18 pm
    A potential client has an intro made with one of those ‘easy to use’ flash programs. Once I get my hands on it I need to import it to AE to use it as part of a project.
    I’m illiterate when it comes to Flash. Is it possible to import to AE then do a final output for video?
    -Frankie
    Filip Vandueren replied 20 years, 10 months ago 2 Members · 1 Reply
  • Filip Vandueren
    November 9, 2005 at 3:50 pm
    It depends,
    if the animation is keyframe based in Flash, then you can open it in Flash and export the frames to a Quicktime or a pict-sequence.
    You do need Flash though. You can’t just drop a swf or fla on AE.
    If the animation is achieved via Actionscript: you’re in trouble.
    I don’t know of a way to do a true convert to a movie.
    You might workaround it with a screengrab tool that is able to capture animations.
