Activity Forums Adobe Premiere Pro FLASH in PREMIERE
  • FLASH in PREMIERE
    Posted by Shawn Harrison on February 26, 2014 at 11:34 pm
    Hey guys so I have a throwback request. The client wants me to encode some videos in flash to these exact specs. Would that be possible in premiere? If not how can I? In Flash? I have never used flash before. Thanks in advance.
    Each video submitted needs 4 components:
    1) Video
    · Format: all videos must be submitted in FLV format (flash video file)
    · Resolution: minimum should be the designed HxW of the player, which is 600Wx338
    · Bitrate: anything between 500kbps and 1MBps is acceptable
    2) Thumbnail Image
    · 100×57 pixels
    3) Poster Image
    · 600Wx338 optimized JPG (under 100K, progressive)
    4) Closed Caption
    · .xml
    Al Levine replied 12 years, 6 months ago 2 Members · 2 Replies
  • Al Levine
    February 27, 2014 at 12:29 am
    Here’s a workflow idea:
    Convert the SWF to .MOV (ProRes is good) in After Effects.
    Bring into Premiere to do your Closed Caption file. Instructions here:
    https://helpx.adobe.com/premiere-pro/using/closed-captioning.html
    Export using ProRes or a high quality setting.
    Then use Adobe Media Encoder to make your FLV
    And Adobe Photoshop to make your Poster Image.
  • Al Levine
    February 27, 2014 at 12:45 am
    Sorry, assumed your video was an SWF. Animation life has gotten the best of me.
    If it’s just video, use Media Encoder to do your FLV files and Premiere for your CC files.
