Activity Forums Compression Techniques Flash Frames in a WMV
  • Flash Frames in a WMV
    Posted by Andrea Stewart on May 15, 2014 at 2:46 pm
    Has anyone else experienced flash frames showing up at cut points that don’t show up in your edit in FCP or in a quicktime output from FCP?
    I made WMVs from reference QTs using Sorenson Squeeze. I’m sure it must be a problem in my settings that is catching the wrong half of a frame or something at a cut?
    Andrea Stewart replied 12 years, 3 months ago 2 Members · 4 Replies
  • Craig Seeman
    May 15, 2014 at 2:55 pm
    You may want to try self contained rather than reference Quicktimes.
  • Andrea Stewart
    May 15, 2014 at 3:08 pm
    Sorry, yes they were self contained. Though I must admit I did not watch them on an NTSC monitor.
    However, the flash frames were showing up on the computer monitor.
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
  • Craig Seeman
    May 15, 2014 at 3:14 pm
    Did you use forced key frames or the equivalent in your encoding?
    Try changing that setting and see if it helps.
    You could test encode to another codec to see if the issue is “universal” to the source.
    Make sure you source QT is ProRes or other I-Frame codec.
  • Andrea Stewart
    May 15, 2014 at 3:16 pm
    I did indeed have keyframes set to every 10 seconds. I will give your idea a try.
    Andrea Stewart
