Activity Forums Compression Techniques Flash frames and dim frames appearing right before cuts
  • Flash frames and dim frames appearing right before cuts
    Posted by Josh Minor on December 6, 2012 at 10:33 pm
    I’ve been trying to burn some DVDs of a feature length doc, but the output always has either a dim frame or a flash frame that appears in one frame right before most of the cuts in the film. The original format is Apple Prores 422hq, 23.98 fps. I should also note that the video track is in a single track in FCP. I previously exported the cut using “current settings” under the “Quicktime Movie” export option in FCP, and then brought the export back into FCP and placed it on track v1. There is also a text track that sits on top of that video track throughout 99% of the film (watermark in the right lower third). There are no flash or dim frames when viewed in FCP. My compression/burn process goes like this: I send my FCP project to compressor, the film is under 2 hours so I use the “DVD Best Quality 120 minutes” compression settings. I then import the assets into DVD Studio Pro. When I preview the video in DVD studio pro, I can already see these dim/flash frames, so I doubt it has anything to do with the actual burn process. I am at a loss as to why this might be happening, any thoughts?
    Just for reference, here are the specs for the “DVD Best Quality 120 minutes” setting in Compressor:
    Name: MPEG-2 5.0 Mbps 2-pass
    Description: Fits up to 120 minutes of video with Dolby Digital audio at 192 Kbps or 90 minutes with AIFF audio on a DVD-5
    File Extension: m2v
    Estimated size: 2.2 GB/hour of source
    Type: MPEG-2 video elementary stream
    Usage:SD DVD
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic
    Average bit rate: 5 (Mbps)
    2 Pass VBR enabled
    Maximum bit rate: 7.5 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 1/2 second, Structure: IBBP
    DVD Studio Pro meta-data enabled
    Craig Seeman replied 13 years, 9 months ago 2 Members · 1 Reply
  • Craig Seeman
    December 11, 2012 at 12:43 am
    You may want to post the exact version of FCP and Compressor as it seems you’re not talking about FCPX 10.0.7 or Compressor 4.0.6.
    You may want to include the codec, frame size, frame rate of what you are exporting out of FCP(version?) since you mention “original source” but don’t mention timeline settings.
    Once people have to make assumptions you’ll get many guesses with unknown accuracy or maybe no response at all. Please read the sticky post at the top of this forum for FASTEST help. That may help.
