Activity Forums Adobe Encore DVD Flash File from Encore & BD won’t burn in Encore
  • Flash File from Encore & BD won’t burn in Encore
    Posted by Adam Berch on April 29, 2013 at 2:57 pm
    I want to make a Flash File from a Blu-Ray I set up in Encore.
    I know how to do that, If I do that, will I be able to preview all of menus and links to see if everything is working correctly before I burn it?
    I went to burn it last night and it said that I had a “Code 25 Error – Not enough disc space.”
    This is confusing because I was using a 25 GB BD Disc and I only used 21 GB or it (According to Encores Build Menu)
    So I went and I made an ISO folder and I’m trying to burn it on something called DVD Fab 9. We will see how this comes out or if it even works?
    Is there a better program to burn my DVD’s in if I can/t burn them in Encore and I have to make ISO Files all of the time?
    Also, when I made my ISO folder it came out to be 25.71 GB, much more than what Encore was saying. When I made a Dlu-Ray folder (same project) it came out to be 24.05 GB.
    Why are all 3 sayiong different file sizes?
    Thanks in advance for all of your help.
    Encore CS 5.1
    Mac Pro
    10 GB RAM
    Adam Berch replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
