Activity › Forums › Adobe After Effects › Flash Export Plug-in?
  • Flash Export Plug-in?
    Posted by Matthew Ingram on July 6, 2006 at 4:54 pm
    I know AFX ships with a Flash Export feature, but it renders out the equivalent of a gigantic EPS sequence.
    Does anyone know if there is a more sophisticated Flash Exporter than gets closer to the Flash scene file (in the way for instance Toon Boom Studio exports a “proper” Flash scene?)
    Steve Roberts replied 20 years, 3 months ago 3 Members · 3 Replies
  • Vince Becquiot
    July 6, 2006 at 7:07 pm
    Matthew,
    It really depends on the type of effects / filters you are using. In general, anything non vector based will render as full image frames and you basically would almost be better of with a flash movie.
    Vince
  • Matthew Ingram
    July 7, 2006 at 9:20 am
    not sure you quite grasp what i’m asking vincent. i don’t think i could have made myself much clearer.
    but never mind, thanks for taking the time to reply.
  • Steve Roberts
    July 7, 2006 at 12:34 pm
    Hmm … do you want:
    1) a relatively small SWF file or
    2) an FLA file?
    1) to make a small SWF file you need to make sure your comp only uses “supported features”, as outlined in the Help … but I think you knew that.
    2) AE can’t make FLA files, plugin or not.
    Does that cover it?
