Activity › Forums › Maxon Cinema 4D › Flash export Cinema 4d 11
  • Flash export Cinema 4d 11
    Posted by Olly Bea on December 15, 2009 at 2:41 pm
    Hey
    Am I being very stupid here? I have attached the FlashEx Tag to an object I want to render out as an swf file, but I cannot find where in the render settings dialogue box to select “export as .swf”. This is driving me insane!
    Can anyone help a very dumb user”?
    Cheers
    Olly
    Jason Linn replied 15 years, 5 months ago 4 Members · 4 Replies
  • Nolan Scott
    December 15, 2009 at 8:07 pm
    Go to Render (top toolbar) FlashEx…
    If you’re are using a Mac, FlashEx does only work on 32-bit systems…not 64-bit systems…
    (as far as I know…)
    Regards
    Nolan
  • Olly Bea
    December 16, 2009 at 1:36 pm
    Brilliant, thanks Nolan
  • Mattias Lindberg
    June 19, 2010 at 9:29 pm
    If you select the CINEMA 4D.app file in Finder and press CMD + i, then you can choose to open Cinema 4D in 32-bit mode. When you do this, FlashEx shows up again, when your using Snow Leopard.
  • Jason Linn
    May 4, 2011 at 12:24 am
    This is SUCH a helpful tip! thanks!
    https://www.jasonlinn.com
