Activity › Forums › Web Design (WordPress, Joomla, etc.) › Flash Dynamic Text Problem
  • Flash Dynamic Text Problem
    Posted by Kathy Summers on June 4, 2010 at 11:03 pm
    I am having a problem with the dynamic text on a site I am designing.
    I am not a proficient Action Script coder, so this may be a simple solution.
    The text is meant to look as though it is typewritten, with each letter appearing separately. This part works fine. The text box should then disappear, however, and I can’t get that to work. Any ideas on how to do this? I tried using motion tweens and adjusting the alpha via the timeline, but I had horrible results and all I had was flickering text. I think I just need a little bit more Action Script code.
    I am using AS3.
    Here is the code:
    var str:String = ‘”jennifer brings exactly the kind of personal warmth and professionalism that is ideal for that special day.” -cynthia bartley, mother of the bride’;
    var i:uint = 0;
    var timer:Timer = new Timer(40);
    timer.start();
    timer.addEventListener(TimerEvent.TIMER,gotime);
    function gotime(e:TimerEvent) {
    textbox_txt.appendText(str.charAt(i));
    i++;
    if(i>=str.length) {
    timer.stop()
    Any help is greatly appreciated. Thanks.
    Kathy Summers replied 16 years, 3 months ago 2 Members · 2 Replies
  • Fernando Mol
    June 6, 2010 at 3:29 pm
    Actionscript is the programming language for Flash. You may get better advice for this question on the Flash forum.
    I have achieved the effect you’re mentioning, but not using Actionscript, also, not with dynamic text. Just plain animation using masks and fades.
    *Always share a link to your site and rate the posts. This is a free service for you and for us.
  • Kathy Summers
    June 8, 2010 at 3:59 pm
    Thanks Fernando. I will try there.
    Kathy
