Activity › Forums › Web Design (WordPress, Joomla, etc.) › flash detection and express install scripts?
Posted by Markmc on March 16, 2006 at 11:49 pmWould somebody be so kind as to tell me if these scripts are correct? I don’t think it’s working. https://www.leroymotors.com/index.htm
Thanks!Markmc replied 20 years, 6 months ago 2 Members · 4 Replies -
Curtis Thompson
March 17, 2006 at 1:22 amhello…
i only got audio on my safari osx box – can you describe what your desired goal is and what isn’t happening in that goal?
sitruc
Markmc
March 17, 2006 at 2:22 amMy client was showing the website to someone and apparently the machine did not have Flash or possibly didn’t have version 8 so the content was blank. There is an flv with playback controls so Flash 8 is required. I watched a tutorial at lynda.com on implementing flash detection scripts using the kit from macromedia. But when a friend tried to view it on his laptop which doesn’t have Flash it did not prompt him to install Flash.
Curtis Thompson
March 17, 2006 at 6:57 pmhello…
ok – tried on windows ie and i get the video but i also get a series of script errors. that is probably your culprit. try enabling script errors in ie…
https://northstar.northseattle.edu/csc/courses/csc110/resources/HowToEnableJavaScript.htm
…and doing some debugging on the code to see if you can get rid of those…
sitruc
