Activity Forums Apple Final Cut Pro Legacy Flash Animations received at 10fps
  • Flash Animations received at 10fps
    Posted by Jeffrey Lonigro on March 9, 2010 at 12:50 pm
    I am compositing some blue screen footage with some Flash animation. I had the Flash artist render out the work at 1280×720 Animation codec 30fps. What I got was everything but the frame rate. It says 10fps in FCP. Is this correct, and or is tis going to work?
    Rafael Amador replied 16 years, 6 months ago 3 Members · 3 Replies
  • Rafael Amador
    March 9, 2010 at 1:50 pm
    If your sequence is 30fps, a 10fps animation will look very choppy.
    Rafael.
    http://www.nagavideo.com
  • John Fishback
    March 9, 2010 at 3:03 pm
    In my experience, most Flash animators work at 10 or 12fps. He probably used the default by mistake. You might try to change the frame rate with Compressor. Be sure to turn on Frame Controls and select best for rate-conversion. 10 to 30 is a big jump, so it still might not look very smooth.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Rafael Amador
    March 9, 2010 at 4:53 pm
    I agree with Dave.
    For an animation 10 or 12 fps is OK, but if you have to compose it with video, won’t work.
    Tell your animator to export with the same time-base than you intend deliver.
    And if you are ending interlaced, ask interlaced.
    Rafael
