Activity › Forums › Adobe After Effects › Flash animation using AE?
  • Flash animation using AE?
    Posted by Brian Dugan on August 16, 2005 at 2:36 am
    In a bind… I ‘heard’ that you can create ‘Flash’ (.swf files) animations in AE.
    I told a client I can do it! Now I gotta really do it! Can anyone steer me in the right direction
    with some ‘fast track’ info? (practice…I know, I know…)
    I just need the final animation file to be a flash file. No interactivity needed.
    Brian
    Brian Dugan replied 21 years, 1 month ago 3 Members · 3 Replies
  • Steve Roberts
    August 16, 2005 at 3:49 am
    You just animate normally and use file>export.
    However … if you want the SWF file to be small, it has to be vector-like, not rasterized. To make it so, you should search the AE help for “SWF”. The help will list the AE features that you should not use if you want a small SWF file. Actually, I think it lists the features that do work, since that’s a smaller list. 😉
    For example, almost all effects will give you a huge SWF file, because AE will rasterize every frame, effectively giving you a sequence of JPEGs in your SWF, and that doesn’t make for a small SWF file.
    The result of all this is, if you want a small SWF file, it will definitely not use AE to its potential, and you may be disappointed at the restrictions. But hey, that’s the Flash format. 🙂
    Anyway, search the help.
    Steve
  • Joe Hayden
    August 16, 2005 at 2:13 pm
    Frame Rates will affect the size also. Using 15 fps or even 8 depending on your movement should make a difference.
  • Brian Dugan
    August 16, 2005 at 2:49 pm
