Activity Forums Apple Final Cut Pro Legacy FLASH AND FCP
  • Posted by Devious1 on August 2, 2007 at 5:30 pm
    Hello. I have searcehd all the forums and cannot find a solution.
    I have two .fla files that I need to export into FCP. U have tried everything possible in Flash 8. I have set the Publish settings for Flash 5 (Flash 8 wouldn’t work) and published a QT .mov file. This worked for ONE of the files, but not the other. Well, kind of. I got it to play in QT, but when I imported it into FCP, it would only play 1 second of the 10 seconds in the clip. I tried to export the mov file in QT to a NTSC mov file, but that only exported 1 second of the clip.
    The second .fla file I can’t seem to do anything with!
    I am to the point that I really just need to pay someone to get the conversion done for me so I can finish this video project (deadline Friday night!). I have spent 2 days on the phone and on the foums trying just about everythign and can’t get this to work, so any help is HUGE!
    Thank you.
    Matt
    Marco Solorio replied 19 years, 1 month ago 4 Members · 4 Replies
  • John Fishback
    August 2, 2007 at 6:32 pm
    The best way to do this might be to capture the Flash movie as it plays with a scan converter or one of the screen capture apps out there.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • David Roth weiss
    August 2, 2007 at 7:07 pm
    That’s a great idea, especially as FLA files, while they do contain FLASH video, are not strictly speaking FLASH video like SWFs and FLVs, which are much easier to convert. iShowU is a very nice and inexpensive screen capture shareware app that will work perfectly for this situation.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Devious1
    August 2, 2007 at 11:26 pm
    Thank you both for the suggestion. It turns out the file itself is weird and the creator couldn’t even get it exported correctly. I have currently gone old school and videoed it off a full screen loop, but I am def going to look into the above stated software.
    Thanks for the help!
    Matt
  • Marco Solorio
    August 2, 2007 at 11:55 pm
    Just to let you know raw Flash FLA authoring files wont work anyway… only published SWF files or FLV video files, which in of themselves don’t import directly into the FCP timeline last I checked. SWF files are easier to transcode than FLV files even though FLV files are video files.
    Since FCP will need a QuickTime video, you might as well use the screen capture method as mentioned above instead of dealing with transcoding.
    Marco Solorio
