Activity › Forums › Adobe After Effects › Flares and transparency
Posted by Ed Romero on October 27, 2010 at 1:23 pmI’m creating a title with a flare that makes the titles appear. But without the footage, or any layer under the flare layer, I don’t see the flare(flash of light effect)
How can I make that flash of light(flare) appear without any layers below it?
Thank you.
Michael Szalapski replied 15 years, 11 months ago 4 Members · 6 Replies -
Ed Romero
October 27, 2010 at 5:23 pmhey Dave,
How can I make the flare visible without any footage below it to render the comp(with no footage/solid when rendered)?
When I render out the comp with no footage the flare is gone… So I’m wondering if there is a way to render the comp with the flare (light flash effect) to be able to overlay it in Final Cut as a title. Even when I turn off the footage in After effects, the flare is gone, but if I turn the footage back on then I see the flare.
Is this possible without any footage/solid below the flare layer? I can think of another way which does require the footage and creating a mask of the area I want to affect, but I’m wondering if there is a better quicker way?
Ed Romero
October 27, 2010 at 7:29 pmThanks again Dave. Links were informative.
However, the only issue I have is that with the footage layer turned off, I can’t see the flare in AE. (Blend mode set to normal on flare layer)
I don’t think my question is clear enough. -
Andrew Donaldson
October 27, 2010 at 8:19 pmAre you applying the flare to an adjustment layer?
If you are, then you’ll need something underneath it, even if its just a black solid.
Chris Wright
October 27, 2010 at 8:42 pmsometimes even with an alpha channel, you want a boost. You probably found that out with transfer modes. If you like the look of premultiplied effects, you get them separated again with this post.
https://forums.creativecow.net/thread/2/989045#989055
https://forums.creativecow.net/thread/2/988892#988892https://technicolorsoftware.hostzi.com/
Ed Romero
October 27, 2010 at 9:29 pmHey Andrew
Yes it’s an adjustment layer. However I can’t use a solid below the adjustment layer because I need to see through the solid. (overlay/screen wont work)
I just need the flare to affect the text layer, but without the footage or a solid of some kind, the flare does not affect the text.CURRENT LAYOUT IN TIMELINE:
1)Adjustment layer with Flare effect. (Adjustment layer affecting layers behind it is active)
2)Pre-comp composition containing animated text and another pre-comped compositing within containing animated lines.
3)Footage.The flare won’t affect the Pre-comped text layer(2) unless I have the bottom layer [(1) Footage] visible, or a solid.
Just noticed Chris’s post. Will check it out to see if that helps.
Michael Szalapski
October 29, 2010 at 1:38 pmYou can apply your lens flare to a black solid and use the free Unmult plugin (Google should find it pretty fast) to make it transparent.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
