Activity › Forums › Adobe After Effects › Flare plugin
Flare plugin
Posted by John Mark on January 26, 2015 at 1:27 amHello CC,
Where can I purchase a flare similar to this one below on the TEN LOGO:
https://www.youtube.com/watch?v=Y4CNK3UNaUs
– Thanks!
Tudor “ted” jelescu replied 11 years, 7 months ago 4 Members · 4 Replies -
John Mark
January 26, 2015 at 7:23 am -
Paul Esteves
January 26, 2015 at 8:05 amCheck out this tutorial at minute 31: https://www.videocopilot.net/tutorials/the_ring/ Andrew shows how to create a lens flare to rotate around the circle, if that’s what you’re after?
As to the problem with the line. You could make that solid bigger. Or, keep the layer in the correct position (so it fills the whole comp) and just move the optical flare without moving the layer itself.
Tudor “ted” jelescu
January 26, 2015 at 12:58 pmDo not move the layer on which the Flare is applied to- link the flare to a 3d Light and move the Light around in 3d space.
Tudor “Ted” Jelescu
Senior VFX Artist
