Activity Forums Maxon Cinema 4D Flag with wind seamless repetition
  • Flag with wind seamless repetition
    Posted by Gareth Wrafter on March 20, 2009 at 11:48 am
    I have created a flag with wind now when i render it out to the player I want to be able to make it repeat but in a way its looping is seamless and just cant figure out how to do this off the top of my head could anyone help ?
    Sergei Sokolov replied 16 years, 1 month ago 4 Members · 5 Replies
  • Adam Trachtenberg
    March 20, 2009 at 3:35 pm
    The wind deformer won’t loop if that’s what you’re using. What you can do instead is put a noise shader in the flag material’s displacement channel to provide the movement. Most of the noises are loopable via the “Loop Period” parameter.
  • Gareth Wrafter
    March 20, 2009 at 3:43 pm
    its the forces area with in the clothide I am using I was wondering if you could keyframe it to go back to its initial state that was set on the first keyframe
  • Lennart Wåhlin
    March 20, 2009 at 4:55 pm
    Frequency 10 = 1 sec loop
    Turbulence doesn’t loop so you can do as Adam suggested
    add a noise deformer for the turbulence and have
    the FlagDeformer do the “waving”.
    For a look with more “umpf” you can have a look
    at a 8min tut I did (QT) looping Cloth.
    https://www.tcastudios.com/xfiles/ClothLoop.mov
    Cheers
    Lennart
    aka tcastudios
  • Adam Trachtenberg
    March 20, 2009 at 11:00 pm
    That’s awfully clever, Lennart!
  • Sergei Sokolov
    July 27, 2010 at 11:59 am
    Amazing! Lennart, thanks for sharing the knowledge.
    Kind regards,
    Serge!Sokolov
