Activity Forums Adobe After Effects Flag Wave
  • Posted by Toby Van kleeck on February 8, 2007 at 8:24 pm
    Any suggestions for a relatively “easy” way of accomplishing a flag waving effect? I don’t want to shoot video of a flag waving as a foundation because it would kind of defeat the purpose. Any help would be greatly appreciated. Thanks in advance!
    -tvanklee
    Jay Thompson replied 19 years, 7 months ago 6 Members · 5 Replies
  • Justin Productions
    February 8, 2007 at 9:42 pm
    Here’s a very good tut’ from Kathlyn:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/lindeboom_kathlyn/flag_freeform/index.html
    Check it out.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Mike Clasby
    February 9, 2007 at 12:01 am
    If you don’t want to buy a 3rd party plug-in, you can us Wave Warp.
    Just drop your Flag image into a comp that bigger than the Flag. You need that black space around the flag for Wave warp to look right.
    Drag that comp into your final comp (you can’t just Precompose because you need that black space)and apply Wave warp.
    For a test, my setting were:
    Wave Type: Sine
    Wave Height: 12
    Wave Width: 90
    Direction: 60 degrees
    Pinning; Left Edge
    You might want to animate some of these parameters over time to give it a little variation, like gusts of wind.
  • Steve Morris
    February 9, 2007 at 6:12 am
    I used Aharon’s displacement map tutorials to create a waving flag earlier this week. The displacement layer gets kind of tricky when you try to animate it. It does not work the way you think it should. You will need to watch 2 of the 3 displacement tutorials to figure it out.
    Created a displacement map in Photoshop. Make undulating vertical lines. Make sure to use a very soft brush. Then blur the layer. Then follow his tutorials. Then apply a second copy of the displacement map on top of the flag to give it the appearance of shadows. Make sure to reduce the opacity of this layer.
  • Tyler Paul
    February 9, 2007 at 2:16 pm
    I made an animated flag using particular. The techinique is a little complicated to explain at the moment but it looked pretty decent. I’ll post a quick animation and the project file when I get off of work. All you’ll have to do is throw your flag image into a comp. There’s a control set up for the windspeed. Greater wind speed causes more flapping. And it’s entirely 3D.
  • Jay Thompson
    February 10, 2007 at 11:02 pm
    For my money the 3rd party plug-in called “Flag” (for $99)from Zaxwerks is the way to go. I’ve used it tons and with great results.
    -jay
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
