Activity Forums Zaxwerks Flag Generator Issues
  • Flag Generator Issues
    Posted by Tom Daigon on May 7, 2005 at 4:45 am
    I love your new flag generator. There are 2 things I bumped into while going thru the tutorials.
    1. Attach to Layer : The attachment on “Balloon” and “Waving Flag” drifts and
    isnt fixed by updating. I had to make multiple keyframes of offset correction
    2. I get an AE memory leak info window that reads:
    “Tracked memory leaks detected.
    Advanced 3D : 32 bytes
    Durer : 40 bytes leaked
    Open GL : 40 bytes leaked”
    (23 :: 38)
    Since this is version 1.0 I thought this info might be helpful. Keep up the good work!
    Tom
    Tom Daigon replied 21 years, 4 months ago 2 Members · 3 Replies
  • Zax Dow
    May 9, 2005 at 5:06 pm
    Thanks for the message.
    We’ve discovered that some of the Flag Tutorial projects need updating so they will open correctly.
    Did you get the “tracked leaks” message after a crash? Can you send us a series of steps to reproduce the problem?
    thanks,
    Zax
  • Tom Daigon
    May 9, 2005 at 6:52 pm
    The memory leak noitce appeared after trying to open one of the files you mentioned needed updating. The files that open, didnt have the problem.
  • Tom Daigon
    May 10, 2005 at 1:20 am
    What about the tracking issue I noticed…
    “1. Attach to Layer : The attachment on “Balloon” and “Waving Flag” drifts and
    isnt fixed by updating. I had to make multiple keyframes of offset correction.”
    Tom
