Activity › Forums › Adobe Premiere Pro › Fixing shaky/distorted footage from concert
  • Fixing shaky/distorted footage from concert
    Posted by Vasik Greif on May 24, 2013 at 9:31 am
    Hi, I was recording a concert, the camera was on a tripod, but as the music was really loud, everytime the drummer used his kick, the footage is shaky/distorted- when that happens, it looks like this:
    For this kind of shake the Warp stabilizer of course doesn’t work. Is there any other way to fix that? Thanks for help.
    David Ghast replied 13 years, 4 months ago 4 Members · 3 Replies
  • Kris Merkel
    May 24, 2013 at 2:38 pm
    Talk about “Fix it in Post” first thing I would do is invest in a more robust tripod if you are going to continue to record this type of event. You will need to fix this is AE with compositing and will take some time. You could try the warp stabilizer but my guess is that it will not help with this, I could be wrong.
    Is your source footage interlaced? Good luck.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Jeff Pulera
    May 24, 2013 at 4:05 pm
    If your video is interlaced, try to right-click the clip and choose “Deinterlace” under Field Options, might help a little bit??
    Jeff Pulera
    Safe Harbor Computers
  • David Ghast
    May 24, 2013 at 6:32 pm
    premiere doesnt “frame through” things properly, especially if you have interlaced footage or frame blending enabled. To know for sure you have to import your footage into vdub and frame through it and if its interlaced you’ll have to write a script (or use the deinterlace plugin) that drops the proper field to show you what exactly goes on.
    Basically its this sort of thing you want a good tripod for and to know better what your camera is doing inside your footage. All this video engineering stuff is really a pain to deal with, BUT if you can figure out what each frame looks like independent of the other then you can figure out how to remove the ghosting, though this will cause a jump in your footage that you will have to go back through and frame interpolate inbetween the jump which will produce messy results in your case.
