Activity Forums Apple Final Cut Pro Fixing Sensor Dust in Final Cut Pro X
  • Fixing Sensor Dust in Final Cut Pro X
    Posted by Emily Dulla on September 3, 2011 at 5:20 am
    Does anyone know of a way to remove sensor dust / spots in FXP X? Or is Motion the place to do this? Any tips on how to fix this quickly? Thank you!!
    Edward Levinson replied 10 years, 1 month ago 10 Members · 15 Replies
  • 15 Replies
  • Glen Hurd
    September 5, 2011 at 4:11 am
    If you don’t have software that lets you clone from one plate to another, you can achieve the same thing in a more “manual” way using Motion.
    Take the clip into Motion and duplicate it so you have two layers. Drop the opacity of the top layer down so you can see through it – like an onion skin. Then position the top layer in such a way that a clean sample of color, matching where the dust spot is, is directly over the spot. Ideally, if there is camera movement, you want to find a sample that is located perpendicular to the movement of the camera. So if the camera is panning left and right, look for a solution above or below the spot. The closer your sample is to the spot, the easier your job may be.
    Then build a tiny matte that’s barely bigger than the spot, and add a little feather to your taste. That matte is for the top layer, so only the little bit of texture covering the spot is being applied.
    Now increase the opacity of the top layer to 100% and see how it looks.
    If there’s a slight color shift, you can add some color correction to that top layer, or you can even try dropping the opacity a little. This will be something you may need to play with if there is a gradient falling across the footage where the spot is.
    This will at least get you started – without having access to any cloning tools. And because it is sensor dust, you won’t have to track anything, so that part is simple. The feathering on the matte is important so that as the camera pans the scene, the new texture being applied over the spot will slide in and out without drawing too much attention. Depending on camera movement, you may need to work with a new layer everytime the camera moves in a new direction – or if the subject suddenly changes direction. Just dissolve from one layer to another to help with the transition, and you should be able to hide it.
    If it sounds like a lot of work, don’t be too disappointed. Dust-busting and wire-removal are valuable skills.
    PS I just found this link where someone demonstrates the same principle, along with motion tracking, for Motion. Picture’s worth a thousand words.
    https://www.youtube.com/watch?v=I6YppZDF9fc&feature=player_embedded
  • Emily Dulla
    September 5, 2011 at 6:53 am
    Thank you so much Glen! Really appreciate your thoughts on this!!
  • Brendan Gibbons
    September 5, 2011 at 11:58 am
    Hi Emily,
    I released a preset here on the cow a few weeks ago that may or may not help you.
    Have a look here
    https://forums.creativecow.net/readpost/344/3099
    Cheers,
    Brendan
  • Emily Dulla
    September 5, 2011 at 3:56 pm
    Awesome! This is really great – thank you so much!!!
  • Anton Chernenko
    October 28, 2012 at 7:53 pm
    Brendan, the effect works great, but not in Final Cut X v.10.0.6, I updated and cannot use it anymore…
  • Anton Chernenko
    October 29, 2012 at 6:55 am
    great! thanks for sharing this!
  • Saul Kennedth
    December 20, 2012 at 12:18 am
    Simon. I don’t understand how to use your “TKY Clone Effect Updated” effect. Can you explain how to use it? Totally couldn’t figure it out. I have a spec of dust on some footage and I want to remove it. I assumed this worked like the Photoshop clone tool where I can select the little spec of dust and then replace it with a pixel very close to the dust spec. The onscreen controls of the effect don’t make any sense to me.
  • Simon Ubsdell
    December 20, 2012 at 2:10 pm
    [Saul Kennedth] “Simon. I don’t understand how to use your “TKY Clone Effect Updated” effect. “
    Hi Saul
    Here’s a short video that I’ve just made to guide you through using this effect:
    https://www.youtube.com/watch?v=HaB_5O_eruo&feature=youtube_gdata
    Hope that’s helpful – let me know if you have any further questions.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Idalino Da silva
    January 9, 2013 at 2:38 am
    Hey Simon,
    I’m sorry, but how do I add that effect into FCP X?
    Thank you very much,
  • Ryan Ritchey
    September 7, 2014 at 2:06 am
    This looks like just what I need to fix a clip, but did fcpx break it somewhere along the way? It doesn’t seem to do anything beyond showing the crosshairs and pixel location dot in 10.1.3
