Activity Forums Adobe Premiere Pro Fixing scratches on a negative…?
  • Fixing scratches on a negative…?
    Posted by Karel Bata on October 6, 2008 at 8:41 pm
    I’m trying to piece together something watchable out of telecine fragments remaining from a 16mm film I lit some years back. It shows dark scratches and dust which suggests the negative itself was scratched…
    How would I fix this…? I could go through it frame by frame, or is there a clever trick or plug-in? I have Premiere CS3 and AE7 running on Win XP.
    Here’s an excerpt https://www.vimeo.com/1898168
    Seems ironic when a lot of folk are trying to create this look in post!
    Cheers!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Karel Bata replied 17 years, 11 months ago 2 Members · 2 Replies
  • Vince Becquiot
    October 7, 2008 at 3:11 am
    Removing scratches (do you really want to get into this?) will either require a ton of patience or a ton of money. If you ever did rotoscoping and thought it was either tedious or boring, “you ain’t seen nothing yet”.
    There are certainly specialized applications for film restoration, but Premiere isn’t one of them. You could use the clone tool in After Effects, that’s where I would start. After Effects can also get rid of the jumpiness with tracking.
    In the end, is it really that bad, think of all of those who are adding scratches to make their video footage look like film 🙂
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • Karel Bata
    October 7, 2008 at 9:37 am
    Thanks for replying.
    Actually no, it’s not that bad, but there are a few places where it’s a bit distracting. Filmfix has just been recommended to me, and it has a 14 day trial. https://www.redgiantsoftware.com/products/categories/enhancement/film-fix/
    I think what I’ll do is edit what footage I have to look like an old trailer. Should be fun. A B&W film would be good for the DoP showreel.
